ASuba
7 years agowarning after QSYS system generation"Warning: Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance."
Hello I am an newbie to Quartus design tool and its associated tools. I am creating a system with nios11 processor in Qsys and after HDL Generation its shows a warning that "Warning: Number of proc...
Abe
7 years agoIf you're using the GUI, show the TCL window from the View menu. Then paste the above command into the TCL prompt and press Enter. Then run the compilation. Set the number of processors depending on the system that you have (2/4).
This is just a warning and can be ignored. It does not affect the compilation results only affects the compilation time.
