12 years ago
Warning (15610): No output dependent on input pin
Hi guys,
I'm designing a functional unit of DP. I'm getting these warnings for no reason. Is there anybody can help me with it. Any help will be really appreciated.
Note: I attached the project archive.
Warnings:
Warning (15610): No output dependent on input pin "TAU_A"
Warning (15610): No output dependent on input pin "TAU_B"
Warning (15610): No output dependent on input pin "TAU_C"
Warning (15610): No output dependent on input pin "TSR_A"
Warning (15610): No output dependent on input pin "TSR_B"
Warning (15610): No output dependent on input pin "TSR_C"
Warning (15610): No output dependent on input pin "ld_tau"
Warning (15610): No output dependent on input pin "ld_tsr"
Warning (15610): No output dependent on input pin "oper_sel0"
Warning (15610): No output dependent on input pin "oper_sel1"
Warning (15610): No output dependent on input pin "oper_sel2"
Warning (15610): No output dependent on input pin "oper_sel3"
Warning (15610): No output dependent on input pin "oper_sel4"
    The reason is simple and can be seen in the below always block. There are multiple assignments to each x_bus_out, but only the last takes place.
    always @ (TAU_A, TAU_B, TAU_C, TSR_A, TSR_B, TSR_C, TR_A, TR_B, TR_C, tau_w2, tsr_w2, tr_w2)
    begin
    	if(TAU_A == 1)
    	begin
    		A_bus_out = tau_w2;
    	end
    	else
    	begin
    		A_bus_out = 12'hzzz;
    	end
    	if(TAU_B == 1)
    	B_bus_out = tau_w2;
    	else
    	B_bus_out = 12'hzzz;
    	if(TAU_C == 1)
    	C_bus_out = tau_w2;
    	else
    	C_bus_out = 12'hzzz;
    	if(TSR_A == 1)
    	A_bus_out = tsr_w2;
    	else
    	if(TSR_B == 1)
    	B_bus_out = tsr_w2;
    	else
    	if(TSR_C == 1)
    	C_bus_out = tsr_w2;
    	else
    	if(TR_A)
    	A_bus_out = tr_w2;
    	else
    	if(TR_B)
    	B_bus_out = tr_w2;
    	else
    	if(TR_C)
    	C_bus_out = tr_w2;
    	else
    end
    You probably meaned to write (and similar for the other outputs):
      if(TAU_A == 1)
        A_bus_out = tau_w2;
      else if(TSR_A == 1)
        A_bus_out = tsr_w2;
      else if(TR_A)
        A_bus_out = tr_w2;
      else
    Thank you so much FvM. Yes, you are right.
    The warnings disappeared and it replaced by new errors that do not make sense to me.
    I connected the same wire to several blocks and I got these errors.
    It shows only for these two blocks that mentioned below. I did the same for others, but it does not show as an error.
    I attached the new project and thank you again for your time.
    Error (12014): Net "tr_w1[11]", which fans out to "FU_reg:TR_reg_Inst|in0[11]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[23]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[11]"
    Error (12014): Net "tr_w1[10]", which fans out to "FU_reg:TR_reg_Inst|in0[10]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[22]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[10]"
    Error (12014): Net "tr_w1[9]", which fans out to "FU_reg:TR_reg_Inst|in0[9]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[21]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[9]"
    Error (12014): Net "tr_w1[8]", which fans out to "FU_reg:TR_reg_Inst|in0[8]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[20]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[8]"
    Error (12014): Net "tr_w1[7]", which fans out to "FU_reg:TR_reg_Inst|in0[7]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[19]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[7]"
    Error (12014): Net "tr_w1[6]", which fans out to "FU_reg:TR_reg_Inst|in0[6]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[18]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[6]"
    Error (12014): Net "tr_w1[5]", which fans out to "FU_reg:TR_reg_Inst|in0[5]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[17]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[5]"
    Error (12014): Net "tr_w1[4]", which fans out to "FU_reg:TR_reg_Inst|in0[4]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[16]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[4]"
    Error (12014): Net "tr_w1[3]", which fans out to "FU_reg:TR_reg_Inst|in0[3]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[15]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[3]"
    Error (12014): Net "tr_w1[2]", which fans out to "FU_reg:TR_reg_Inst|in0[2]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[14]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[2]"
    Error (12014): Net "tr_w1[1]", which fans out to "FU_reg:TR_reg_Inst|in0[1]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[13]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[1]"
    Error (12014): Net "tr_w1[0]", which fans out to "FU_reg:TR_reg_Inst|in0[0]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_mul_1:amz_mul_1_inst|result[12]"
    Error (12015): Net is fed by "amz_div_1:amz_div_1_inst|remain[0]"
    Error (12014): Net "overflow_sig", which fans out to "FU_reg:TSR_reg_Inst|in0[9]", cannot be assigned more than one value
    Error (12015): Net is fed by "amz_add_sub_1:amz_add_sub_1_inst|overflow"
    Error (12015): Net is fed by "amz_log_shift:amz_log_shift_inst|overflow"
    Error (12015): Net is fed by "amz_arith_shift:amz_arith_shift_inst|overflow"
    Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 40 errors, 1 warning
    Error: Peak virtual memory: 435 megabytes
    Error: Processing ended: Thu Feb 27 10:34:49 2014
    Error: Elapsed time: 00:00:02
    Error: Total CPU time (on all processors): 00:00:02
    You apparently appended the old archiv. It has the old warnings but no multiple driver errors.
    --- Quote Start ---
    --- Quote End ---
    The errors are justified. You can't connect the same net to multiple module output ports. A multiplexer must be connected intbetween to select which output drives the net at a time.
