Warning 12620, quaruts pro 21.1, DDR3 EMIF
Thanks, Adzim_Intel, but I am not sure what you are asking me.
When you ask about comparing with the example project; I have recreated all the parameters and settings of the example project exactly as far as I can tell. The example project calibrates, my re-creation does not.
The reset signal is tied to a push button on the board. It does not occur during calibration only when I press the button.
Do you have the calibration report for this failure?
Or do you mind to share the project with me?
I want to replicate the issue and help you debug this issue.
- TSchu35 years ago
I will get those files to you today. Thanks
- TSchu35 years ago
Here is the project that I created based on the example project. It is intended to do nothing other than instantiate the EMIF controller and calibrate the DDR3.
- AdzimZM_Altera5 years ago
Hi Sir,
Thank you for sharing the project file.
I will test the project.
But unfortunately due to current situation, I'm not able to get the board yet.
So for now can you provide the Calibration report?
Adzim
