TSchu3
5 years agoWarning 12620, quaruts pro 21.1, DDR3 EMIF
Hello, I am encountering an error within generated IP and I'm hoping for some help.
Quartus Pro 21.2 and 17.1 Cyclone 10 gx development board The overall problem I am trying to solve is calibra...
sstrell
5 years agoSorry, I completely missed that this was Pro and Cyclone 10 GX. You don't have to run that script for this device.
Did you match the pin locations between the example project and your manually created IP design?
- TSchu35 years ago
I copied the pin assignments from the example project .qsf file. I also manually verified them at least twice. There could be a mistake lurking but I have not found it.
