Maybe I need add some information, the warning points to these lines in the file "src/mss/dmss/tkl3_dmem_dummy_ff.v(53)":
// synopsys template parameter D_WIDTH = 10; It seems Quartus cannot recognize "// synopsys template". - Altera_Forum
It is just a warning not an error. The synthesis process will ignore this "template" directive then this on is not supported by Quartus.
Here you can find a list of supported synthesis directives: verilog hdl synthesis attributes and directives (http://quartushelp.altera.com/11.1/mergedprojects/hdl/vlog/vlog_file_dir.htm) The only way to get rid of the warning is to remove the line with this unknown synthesis directive in your code.
