10 years agoVTAP Tutorial
Can someone provide a tutorial on how to use VTAP in the Max10 devkit? Thank You3 Replies
Do you mean Virtual JTAG?
https://www.ovro.caltech.edu/~dwh/correlator/pdf/vjtag.pdf - Altera_Forum
When programming the Max10 devkit I see VTAP in the JTAG chain. Is this is the same as Virtual JTAG?
--- Quote Start --- When programming the Max10 devkit I see VTAP in the JTAG chain. Is this is the same as Virtual JTAG? --- Quote End --- I'm not sure. A quick Google of the term shows this page ... https://rocketboards.org/foswiki/view/documentation/alteramax1010m50revcdevelopmentkitlinuxsetup which implies that it is a hardware jumper ... but to control what? You'll have to read the docs :) Cheers, Dave
