vsim.exe - System Error
Try to install the Microsoft Visual C++ Redistributable for Microsoft Visual Studio 2017 and see if the issue resolved.
Richard Tan
I install Visual Studio 2019 and re-install quartus with fee questa_sim, guesta_fse
but when I try running questa sim, it is ask license as attached.
would you please let me know what I need to do for fix?
Thank you,
Sun
- RichardT_altera4 years ago
Hi @sunkim68
Questa*-Intel FPGA Starter Edition is free, but requires zero cost licenses.
The LM_LICENSE_FILE environment variable specify the location of the license file. Before using Questa*-Intel® FPGA Edition software, you must set an environment variable the location of license.
1. You need to have a license.dat file first. Request the license from the Self Service Licensing Center if you haven't done so.
2. Then, go to "My PC", right click properties
3. Click Advanced System Setting.
4. In the "Advanced" tab, click environment variable
5. In the "System Variable", create a New variable with name= LM_LICENSE_FILE, value= <the path to your license.dat> e.g. C:\license.dat
6. Click Ok and restart the Questa.Or a more straight forward way:
In the command prompt:
setx LM_LICENSE_FILE <the path to your license.dat>For more information, refer to the User Guide below:
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.- sunkim684 years ago
Hi Richard,
Thanks for your information and I am trying to follow-up still I have issues
I generated it, download and set it up as below but I had a error as attached.
C:\Users\sunki>lmutil lmdiag
lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
FlexNet diagnostics on Mon 10/11/2021 13:05-----------------------------------------------------
License file: C:\intelFPGA_pro\21.3\1-UXUQF7_License.dat
-----------------------------------------------------Would you please let me know what I missed?
Sun Kim
Hi @sunkim68
Could you help to share the license .dat file so I could look into it?
Richard Tan
