9 years agoVS2010 build opencl host fail problem
I use VS2010 to build opencl host program. But I can not build it successfully. Before builing the code, I already run the batch file to st PATH. But VS2010 still has error message, how to sol...
9 years agoThere must be some problem with the Visual Studio configuration, then. Have you checked your configuration against the steps mentioned in the getting started guide (https://www.altera.com/en_us/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf)?
