GRAVE2
7 years agoVirtualbox with DE10-Lite USB Scan Problem
I'm running Ubuntu 18.04 with Virtualbox and extensions running with Centos 6 virtual machine. Quartus Prime 18.1.0 is installed and working, and I have worked through several labs in the "4 Hour FP...
- 7 years ago
Found the USB bus was read only. Changed it:
chmod 666 /dev/bus/usb/002/002
The bus and device numbers in path above found with lsusb inside VM.
ShafiqY_Intel
7 years agoHi Greg,
I found almost similar issue on the following forum link. However, this user used usb-blaster II.
https://forums.intel.com/s/question/0D50P00003yyT9pSAE/de1soc-dev-kit-trouble-w-usb-blaster-ii-centos7
Since you already found the solution, it’s good for Intel FPGA communities here to know this workaround. Thank you Greg.
Shafiq
