14 years agoVIP Suite problem
I am trying to run a design with the DVI input output with a simple color plane sequencer in between.I take the DVI input change the color plane from RGB parallel to RGB serial progressive , then reverse it and try to display it on the DVI output without any NIOS , but the output is being buffered from the DDR2 memory on the output.
It is a simple test code to check the use of color plane converter.can anyone tell me if we can use the vip suite components without nios 2 processor. I succeeded before in implementing DVI input op with memory ddr2 but without any nios.But is not working this time.Anyone any opinions ?
