11 years agoVideo Lincence
Hi, I just want to know whether a separate licence is required for SDI, Clocked Video Output and Test Pattern Generator IP cores.:) I can compile the design of Clocked Video output and Test Pa...
11 years agoCan you elaborate about what error you have seen in modelsim-altera starter edition? Are you using SDI or SDI II? Which quartus version you use to generate the SDI & clocked video output IPs?
