15 years ago --- Quote Start --- I might seems logical, but the SOPC builder must be clocked with the pixel clock, whereas I was using a faster clock. I'm a little bit surprised, because I thought the avalon bus needed a faster clock in order to transmit pixels and some others data in real time... and I thought that vid_clk at CVO was used to regenerate the correct video flow. --- Quote End --- The reason you can get away with using the pixel clock in some cases is because of the horizontal blanking interval. The average data rate for a line is actually a little less than the pixel clock. However, I suspect you may still have some other issue in your system. You should be able to use an independent faster clock for the VIP components.
