8 years ago
[VHDL] VHDL-2008 'context' clause of the packages -> not recognized by Quartus Prime?
Hi All,
Does Quartus Prime support VHDL-2008 'context' clause of the packages?
I'm receiving the following error:
Error (10500): VHDL syntax error at t_all.vhd(6) near text "context";  expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration"
for the following file contents:
context t_all is
  library pkgs;
  use     pkgs.t_bit.all;
  use     pkgs.t_lpfsm.all;
  use     pkgs.t_des.all;
  use     pkgs.t_fifo.all;
  use     pkgs.t_ports.all;
  use     pkgs.t_tbl.all;
end context t_all;
It seems Questa Prime does not recognize the context keyword...
So, how to fix/workaround?
Thank you!
