10 years agoVHDL Traffic Light - How to make signals viewable in simulation?
Hi there, relatively new to VHDL. At the end of this description I will post my VHDL code and Test Bench. When I simulate the code, the timing seems to be off, I want it to wait 15 clock cycles...
10 years agoUpdate: Now the timing works just how I want it, with the 15 and 3 clock cycles per change of state, and I made it more efficient.
If someone could still tell me how to bring out internal signal in the simulation that would be appreciated, thank you. ---------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 05/24/2016 10:20:40 AM -- Design Name: -- Module Name: Traffic_Light_VHDL - Behavioral -- Project Name: -- Target Devices: -- Tool Versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_arith.all; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values use IEEE.NUMERIC_STD.ALL; use ieee.std_logic_unsigned.all; -- Uncomment the following library declaration if instantiating -- any Xilinx leaf cells in this code. --library UNISIM; --use UNISIM.VComponents.all; entity Traffic_Light_VHDL is Port ( Reset : in std_logic; clk : in std_logic; MG : out STD_LOGIC; MY : out STD_LOGIC; MR : out STD_LOGIC; SG : out STD_LOGIC; SY : out STD_LOGIC; SR : out STD_LOGIC ); end Traffic_Light_VHDL; architecture Behavioral of Traffic_Light_VHDL is type state_type is (st0, st1, st2, st3); --signal PS, NS : state_type; signal state : state_type; signal Count : std_logic_vector(3 downto 0); begin process(clk, Reset) begin if (Reset = '1') then state <= st0; Count <= "0000"; elsif (rising_edge(clk)) then case state is when st0 => if (Count < "1111") then Count <= Count + 1; else state <= st1; Count <= "0000"; end if; when st1 => if (Count < "0011") then Count <= Count + 1; else state <= st2; Count <= "0000"; end if; when st2 => if (Count < "1111") then Count <= Count + 1; else state <= st3; Count <= "0000"; end if; when st3 => if (Count < "0011") then Count <= Count + 1; else state <= st0; Count <= "0000"; end if; when others => state <= st0; end case; end if; end process; process(state) begin case state is when st0 => MG <= '1'; SR <= '1'; MY <= '0'; SY <= '0'; MR <= '0'; SG <= '0'; when st1 => MG <= '0'; SR <= '1'; MY <= '1'; SY <= '0'; MR <= '0'; SG <= '0'; when st2 => MG <= '0'; SR <= '0'; MY <= '0'; SY <= '0'; MR <= '1'; SG <= '1'; when st3 => MG <= '0'; SR <= '0'; MY <= '0'; SY <= '1'; MR <= '1'; SG <= '0'; when others => MG <= '1'; SR <= '1'; MY <= '0'; SY <= '0'; MR <= '0'; SG <= '0'; end case; end process; end Behavioral;
