13 years ago
VHDL test bench
I don't know how to write test bench coding and i don't know how to see the output.I am writing a simple programme of and gate below:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity mrinalnt is
Port ( a : in STD_LOGIC;
b : out STD_LOGIC);
end mrinalnt;
architecture Behavioral of mrinalnt is
begin
b<= not a;
end Behavioral;
Now for test bench the following code is,It is not right,please help....
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.ALL;
ENTITY mrinaltst IS
END mrinaltst;
ARCHITECTURE behavior OF mrinaltst IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT mrinalnt
PORT(
a : IN std_logic;
b : OUT std_logic
END COMPONENT;
--Inputs
signal a : std_logic := '0';
--Outputs
signal b : std_logic;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: mrinalnt PORT MAP (
a => a,
b => b
-- No clocks detected in port list. Replace <clock> below with
-- appropriate port name
constant clk_period := 1ns;
clk_process :process
begin
clk <= '0';
wait for 15ns;
clk <= '1';
wait for 15ns;
end process;
-- Stimulus process
stim_proc: process
begin
-- hold reset state for 100ms.
wait for 100ms;
wait for <clock>_period*10;
-- insert stimulus here
wait;
end process;
END;
I don't know what to write in stimulus process,how to declare signal etc....
1 Reply
    for the stimulus, you write whatever you wan to input a, and watch the result come out on signal b.
    eg:
    a <= '0';
    wait for 100 ms;
    a <= '1';
    wait for 100 ms;
    a <= '0;
    You need a simulator like modelsim to run this code.
