14 years agoFirst of all - this is an altera forum - ISim is a Xilinx Tool.
Secondly, without your code (or a simplified demo that I can run) there is no way I can recreate your problem, so at the moment it just appears to be a problem for you to debug yourself. I have no idea where you are causing the error (because it will be an error in the code, that I cannot see)
