14 years agoThe 'p' and 'U' values are incorrect, for some reason it outputs early, 'U' is Unknown, you can see that it outputs at 3 ns with an Unknown Value (which should not occur) and then 1 ns later updates to the correct value. Those lines should be outputting at 5ns after instead of 3 / 4 ns like they are. I am using ISim 0.61xd.
