17 years agoTry this for size:
below your signal declarations add:constant period_shift : unsigned (timecounter'length - period'length - 1 downto 0) := (others => '0'); this creates a vector of all zeroes whose length is determined by the length of timecounter and period- i.e. suppose you change periodto be 10 bits - this line stays the same. Then in your process put: nexttime <= timecounter + (period & periodshift); Again if you change the range of period or timecounter then everything rolls through automatically and you don't have to update any other code. Regarding mmTuschi's question: --- Quote Start --- Does outputsignal <= ((23 downto 16) => inputsignal(7 downto 0), others => '0'); work ? --- Quote End --- I think it works for individual bits but not for ranges like this - unless one of the more recent VHDL standards have changed this and I haven't noticed. On a slightly different note, most people I know prefer numeric_std over std_logic_unsigned or signed - the latter two aren't actually IEEE packages but Mentor / Synopsis packages that have cheekily been compiled into the IEEE library. numeric_std is an IEEE standard. Hope this helps.
