17 years agoThank you, it clarified a part of what I was thinking.
Another take on this. using ieee.std_logic_unsigned but could change to numeric_std if I needed. I have inputs from another module: signal timecounter: unsigned(31 downto 0); signal period: unsigned(7 downto 0); And a signal that is used for a schedule off the main timer. signal nexttime: unsigned(31 downto 0;
process(clk)
if(clk'EVENT and clk = '1') then
if(timecounter = nexttime) then
-- do stuff
-- do more stuff
-- This is where the problem begins, need to cast the period(7 downto 0) to (31 downto 0) somehow and shift it left by 24 bits.
nexttime <= timecounter + period shifted left by 24 bits
end if;
end if;
end process;
One solution I can think of is to do an assignment as above with a variable in the process, and then use the variable in the add operation. I'm just wondering if there is a prettier way.
