17 years agoHi Frank
Daixiwen is correct - this works inside a process - sorry I should have said that. Basically in a process, the last assignment is the one that takes effect. The result of this is that you can make a default assignment right at the beginning of the process and then effect changes to the default with or without conditions. e.g.:
process (set_to_ones, do_something_else)
begin
output <= (others <= '0');
if set_to_ones = '1' then
output <= (others => '1'(;
elsif do_something_else = '1' then
output <= "1ZX0HL-U";
end if;
end process; Basically this means that if none of the if branches execute, then the (others => '0') assignment will be output; if one of the other signals is high then the default (others => '0') assignment is overwritten and has no effect. Going back to baldur's query, if I write:
process
begin
outputsignal <= (others => '0');
outputsignal (23 downto 16) <= inputsignal;
end process; then the (others => '0') gets assigned to all bits, but some bits have this overridden by the next statement. Bits 23 downto 0 never in effect see the '0' assigment.
