10 years agoVHDL sequential vs concurrent statement
Hi, I am bit confused over sequential vs concurrent statements in VHDL. In almost all books, it is mentioned as process body will contain sequential statements. Consider following code fragment...
10 years ago --- Quote Start --- Thank you, Tricky..very much appreciated. Sorry to restart after so long, was badly stuck somewhere else.. So can I conclude that if we do multiple assignments to different signal (within a single process block) then the difference between sequential signal assignment and concurrent signal assignment matter for simulation purposes only. There is no difference for synthesizeable code (e.g. the code I posted in first post)? --- Quote End --- The code you posted was very trivial. But you shouldnt care about the signal assignments in simulation or synthesis. If you get a missmatch between simulation and synthesised hardware, there is a problem - usually a problem of poorly written code. Ie. never use shared variables!
