10 years agoVHDL sequential vs concurrent statement
Hi, I am bit confused over sequential vs concurrent statements in VHDL. In almost all books, it is mentioned as process body will contain sequential statements. Consider following code fragment...
10 years agoThank you, Tricky..very much appreciated. Sorry to restart after so long, was badly stuck somewhere else..
So can I conclude that if we do multiple assignments to different signal (within a single process block) then the difference between sequential signal assignment and concurrent signal assignment matter for simulation purposes only. There is no difference for synthesizeable code (e.g. the code I posted in first post)?
