10 years agoVHDL sequential vs concurrent statement
Hi, I am bit confused over sequential vs concurrent statements in VHDL. In almost all books, it is mentioned as process body will contain sequential statements. Consider following code fragment...
10 years agoThis is where you need to understand vhdl mechanics. Firstly, a single line vhdl statement actually infers a process with all the signals on the rhs in the sensitivity list. Si you actually have 3 processes in parallel. Secondly, signals are only updated when a process suspends. When a signal assignment is made, it is only scheduled to be updated at the end of the current delta cycle, so all three signals are updated at the same time.
