18 years agoFirst check that you are using the correct coding style for dual-port RAM. I think support for inferred true dual ports is fairly new. (Maybe what's new is for dual-clock true dual ports--I don't remember.) It's probably covered in the Quartus handbook, most likely in the chapter referenced at http://www.alteraforum.com/forum/showthread.php?p=3369#post3369.
