8 years ago[VHDL] how to manage lib name depending on the design entry?
Hi All, I want to use the different library names for the same Le's say I have a VHDL file with the following lines: library mylib_1;use mylib_1.abc.all; But, when I'm go...
8 years agoimport package my_pkg in SV is equivalent to use my_pkg in vhdl.
Compiling a unit into multiple libraries is perfectly fine. Whats the problem here? vcom -work my_lib1 abc.vhd vcom -work my_lib2 abc.vhd Now abc exists in both libraries. remember, you can refer to items in the same library using work. Work is not a library itself, it can be thought of as a "local library" So, why not post some code with what you're trying to do. Compiling the same thing into multiple libraries seems like an odd concept to me. A library should be a static thing containing static objects. I dont understand why you would want it in another library.
