16 years ago
VHDL: How to find my library in Quartus?
I have a vhdl project and am trying to instantiate a component. Can you tell me how to find the name of my libary?
    hmm well instead of starting another thread, i'll try to ask here..
    I thought that calling that way would fix the problem but i still get the same error i was trying to evade:
    --- Quote Start ---
    Error: Port "Reset" does not exist in primitive "tff" of instance "tff0"
    --- Quote End ---
    it happens on this line:
    tff0  : entity work.TFF port map( enable, clk, rst, Qout(0));
    of this file:
    LIBRARY ieee;
    USE ieee.std_logic_1164.all;
    USE ieee.numeric_std.all;
    entity TFFcounter16bit is
    	port ( 	enable, clk, rst : in std_logic;
    			Qpin	: out unsigned(15 downto 0)
    end TFFcounter16bit;
    architecture wowee of TFFcounter16bit is
    	signal Qout : unsigned(15 downto 0);
    begin
    	tff1  : entity work.TFF port map( (enable AND Qout(0)), clk, rst, Qout(1));
    	tff2  : entity work.TFF port map( ((enable AND Qout(0)) AND Qout(1) ), clk, rst, Qout(2));
    	tff3  : entity work.TFF port map( (((enable AND Qout(0)) AND Qout(1)) AND Qout(2)  ), clk, rst, Qout(3));
    	tff4  : entity work.TFF port map( ((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3) ), clk, rst, Qout(4));
    	tff5  : entity work.TFF port map( (((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)), clk, rst, Qout(5));
    	tff6  : entity work.TFF port map( ((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)), clk, rst, Qout(6));
    	tff7  : entity work.TFF port map( (((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)), clk, rst, Qout(7));
    	tff8  : entity work.TFF port map( ((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)), clk, rst, Qout(8));
    	tff9  : entity work.TFF port map( (((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)), clk, rst, Qout(9));
    	tff10 : entity work.TFF port map( ((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)), clk, rst, Qout(10));
    	tff11 : entity work.TFF port map( (((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)) AND Qout(10)), clk, rst, Qout(11));
    	tff12 : entity work.TFF port map( ((((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)) AND Qout(10)) AND Qout(11)), clk, rst, Qout(12));
    	tff13 : entity work.TFF port map( (((((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)) AND Qout(10)) AND Qout(11)) AND Qout(12)), clk, rst, Qout(13));
    	tff14 : entity work.TFF port map( ((((((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)) AND Qout(10)) AND Qout(11)) AND Qout(12)) AND Qout(13)), clk, rst, Qout(14));
    	tff15 : entity work.TFF port map( (((((((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)) AND Qout(10)) AND Qout(11)) AND Qout(12)) AND Qout(13)) AND Qout(14)), clk, rst, Qout(15));
    	Qpin <= Qout;
    end wowee;
    which is instantiated from this file:
    LIBRARY ieee;
    entity TFF is
    	port( T, Clk, Reset	: in std_logic;
    			Q			: out std_logic
    end TFF;
    architecture behavioral of TFF is
    	signal buf : std_logic;
    begin
    	process(T, Clk, Reset)
    	begin
    		if(reset = '1') then
    			buf <= '0';
    		end if;
    		if(Clk = '1') then
    			if(T = '1')then
    				buf <= (NOT buf);
    			end if;
    		end if;
    	end process;
    	Q <= buf;
    end behavioral;
    Can someone please help?
    Malik
    Apparently Quartus is instantiating a same name component from an internal library rather than your component. I'm not sure why it's assumed to be part of the library work, it seems to be a kind of reserved name. If you don't mind, you may want to simply change the component name.
    Is it ok to start VHDL topics in this forum? and if not, which section do i use?
