16 years agohmm well instead of starting another thread, i'll try to ask here..
I thought that calling that way would fix the problem but i still get the same error i was trying to evade: --- Quote Start --- Error: Port "Reset" does not exist in primitive "tff" of instance "tff0" --- Quote End --- it happens on this line:tff0 : entity work.TFF port map( enable, clk, rst, Qout(0)); of this file: LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
entity TFFcounter16bit is
port ( enable, clk, rst : in std_logic;
Qpin : out unsigned(15 downto 0)
end TFFcounter16bit;
architecture wowee of TFFcounter16bit is
signal Qout : unsigned(15 downto 0);
begin
tff1 : entity work.TFF port map( (enable AND Qout(0)), clk, rst, Qout(1));
tff2 : entity work.TFF port map( ((enable AND Qout(0)) AND Qout(1) ), clk, rst, Qout(2));
tff3 : entity work.TFF port map( (((enable AND Qout(0)) AND Qout(1)) AND Qout(2) ), clk, rst, Qout(3));
tff4 : entity work.TFF port map( ((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3) ), clk, rst, Qout(4));
tff5 : entity work.TFF port map( (((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)), clk, rst, Qout(5));
tff6 : entity work.TFF port map( ((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)), clk, rst, Qout(6));
tff7 : entity work.TFF port map( (((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)), clk, rst, Qout(7));
tff8 : entity work.TFF port map( ((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)), clk, rst, Qout(8));
tff9 : entity work.TFF port map( (((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)), clk, rst, Qout(9));
tff10 : entity work.TFF port map( ((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)), clk, rst, Qout(10));
tff11 : entity work.TFF port map( (((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)) AND Qout(10)), clk, rst, Qout(11));
tff12 : entity work.TFF port map( ((((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)) AND Qout(10)) AND Qout(11)), clk, rst, Qout(12));
tff13 : entity work.TFF port map( (((((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)) AND Qout(10)) AND Qout(11)) AND Qout(12)), clk, rst, Qout(13));
tff14 : entity work.TFF port map( ((((((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)) AND Qout(10)) AND Qout(11)) AND Qout(12)) AND Qout(13)), clk, rst, Qout(14));
tff15 : entity work.TFF port map( (((((((((((((((enable AND Qout(0)) AND Qout(1)) AND Qout(2)) AND Qout(3)) AND Qout(4)) AND Qout(5)) AND Qout(6)) AND Qout(7)) AND Qout(8)) AND Qout(9)) AND Qout(10)) AND Qout(11)) AND Qout(12)) AND Qout(13)) AND Qout(14)), clk, rst, Qout(15));
Qpin <= Qout;
end wowee;
which is instantiated from this file: LIBRARY ieee;
entity TFF is
port( T, Clk, Reset : in std_logic;
Q : out std_logic
end TFF;
architecture behavioral of TFF is
signal buf : std_logic;
begin
process(T, Clk, Reset)
begin
if(reset = '1') then
buf <= '0';
end if;
if(Clk = '1') then
if(T = '1')then
buf <= (NOT buf);
end if;
end if;
end process;
Q <= buf;
end behavioral;
Can someone please help? Thanks Malik
