11 years ago[VHDL] Help with "stuck at VCC"
I need to make an output pulse (within certain conditions) becomes a '1' constant (in an LED).I was able to code, but the output is stuck at VCC. I do not know how to fix this. Can anyone help me ple...
11 years ago --- Quote Start --- In this case, when the 'enable' stop being '1' the led turns off. And this is wrong, cause the user will not press "enable" button forever. I want if the output is '1' once is forever; regardless of the value of the enable. --- Quote End --- You either change enable to a toggle switch instead of current button or learn how to keep enable high internally using clock edge ...etc. and hopefully LED wouldn't burn
