10 years agoVHDL Help Requested
Hello. I'm a VHDL newbie and request help on coding a counter. I'm trying to synchronize a BTRIG signal to the system clock and then toggle a short_long_sample_q signal every 4 synchronized BTRIG pul...
10 years agoHello
In your code the process controlling short_long_sample_q is asynchronous, which means that it will keep toggling this signal until btrig_counter is different than "11". This is possibly why you are experiencing strange behaviors. Make sure that SYSCLK > 2*BTRIG or else you will not be able to detect a rising edge on this signal I didn't test this code, but you can give it a try:process ( SYS_CLK )
begin
if rising_edge ( SYS_CLK ) then
if (btrig_previous = '0') and (BTRIG = '1') then -- Rising edge detected
if (btrig_counter = "11") then -- Fourth rising edge detected
short_long_sample_q <= not short_long_sample_q;
btrig_counter <= "00";
else
btrig_counter <= btrig_counter + 1;
end if
end if
btrig_previous <= BTRIG;
end if
end process
