Your wording indicates some unclear thoughts. You only need signed thinking. You got nothing to do with unsigned. The value 32767 means +32767 and doesn't mean unsigned. In each case of positive or negative values the MSB is used as sign bit(0 for +, 1 for -).
We are talking here about 2's complement as is the case with most fpga signed computations. Check your DAC number system...
Anyway for conversion between std_logic_vector and signed or unsigned
try numeric_std library.
std_logic <=> signed, std_logic <=> unsigned
just use
direct cast e.g.
d_signed <= signed(data); -- data is std_logic_vector
d_unsigned <= unsigned(data); -- data is std_logic_vector
d_std_logic <= std_logic_vector(data); -- data is signed
d_std_logic <= std_logic_vector(data); -- data is unsigned
for integer to signed/unsigned you need
one stage conversion only,define bitwidth:
I <= to_signed(32767,16); -- I being signed
I <= to_unsigned(32767,16); -- I being unsigned
for integer <=> std_logic_vector you need
two stages(cast plus conversion, you need define bitwidth)
I <= std_logic_vector(to_signed(32767,16)); -- 7FFF, 15 bits magnitude
I <= std_logic_vector(to_signed(-32767,16)); -- 8001h, 15 bits magnitude
I <= std_logic_vector(to_unsigned(32767,16)); -- 7FFF, 16 bits magnitude
edit:
some engineers feel that VHDL is too complicated and unfriendly at this type conversion and have raised concerns to ieee. There is certainly room for improvement and mercy.
