hi sir..
thank you for your quick reply.
i want to ask you about how to convert std_logic_vector to signed and unsigned...
let say.. when input => '1' then
output <= ---------?? (unsigned)
what are the syntax that can be used to convert to unsigned..
and when input => '0' then
output <= ---------?? (signed)
what are the syntax that can be used to convert to signed..
and what are the library that need to be used.. is it use ieee.std_logic_unsigned and use ieee.std_logic_signed or is it enough to just use ieee.numeric_std.all??
hope to hear from you soon.
