sir..
i've been able to create vhdl code for each block in qpsk modulator part.
But, there are 1 block that have an error.
it is for unipolar to bipolar.. i need to the incoming data for both I-channel and Q-channel which consist of logic 1 or logic 0. i want to change logic 1 to 1 and logic 0 to -1.
here are the code that i have write for unipolar to bipolar converter.
----------------UNIPOLAR TO BIPOLAR---------------[LOGIC 0=-1, LOGIC 1=1]-------
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
USE ieee.std_logic_signed.all;
USE ieee.numeric_std.all;
------------------defines two types: unsigned and signed
ENTITY unipolar_bipolar IS
PORT(
in_i,in_q : IN std_logic_vector (3 downto 0); -------4 bit-------
bI,bQ: OUT std_logic_vector (3 downto 0) -------4 bit-------
END unipolar_bipolar ;
ARCHITECTURE beh OF unipolar_bipolar IS
signal p: integer;------------out
signal k: integer;-------------in
signal n: std_logic_vector(3 downto 0);--------------out(final)
signal i:integer; -----------------------for loop 0 until 3 (4 bit)-----------
begin
for i=> '0';
LOOP
i=n;
when in_i(n)=> k & in_q(n)=> k then
case k is
when k ='0' then -----must invert to signed value---[-1]
p <= '1'; -------in std_logic
out_q(n)<= conv_integer(p);
out_i(n) <= conv_integer(p); --------convert into integer(signed)
end case;
case k is
when k ='1' then-----must invert to unsigned value--[1]
out_q(n)<= conv_integer('0'& p);
out_i(n) <= conv_integer('0' & p); --------convert into integer(unsigned)
end case;
n = i+1;
when n='3' loop;
end LOOP;
end beh;
hope you can help me as soon as possible..
thank you so much..
