10 years agovhdl file syntax or logic error result in that ...unable open .vcd
Hi, I am new to Quartus II. I have created a very simple program for shift register in VHDL. It was successfully compiled. Then I create the input wave forms and saved it. When I run it, the la...
10 years agohope qsim directory in file path indicates that you use Universtity Progrma VWF <- is it true?
The first error i've met today face to face: after several succesive runs for functional simualtion and when I've chaged synthesis option i 've started encounter error in vt files, no any changes except for synthesis. even i try to recreate vt file. Try simulate in ModelSim-Altera Starter. And it is not easy provide answer when you say "Quartus II" and what simulation tool you've used. What is version number?
