14 years agovhdl don't care problem
Hello. I am making priority encoder in vhdl and I want to use process, case statement and don't care statement. This is my code and compile is done very well. but in model_sim, the output is alw...
8 years agoif you want to include don't care (-) use this code this works....
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity enc is Port ( i_l : in STD_uLOGIC_VECTOR (7 downto 0); ei_l : in STD_uLOGIC; a_l : out STD_uLOGIC_VECTOR (2 downto 0); gs_l,eo_l : out STD_uLOGIC); end enc; architecture Behavioral of enc is begin process(i_l,ei_l) begin if (ei_l='0') then if std_match(i_l,"0-------") then a_l<="000"; gs_l<='0';eo_l<='1'; elsif std_match(i_l,"10------") then a_l<="001"; gs_l<='0';eo_l<='1'; elsif std_match(i_l,"110-----") then a_l<="010"; gs_l<='0';eo_l<='1'; elsif std_match(i_l,"1110----") then a_l<="011"; gs_l<='0';eo_l<='1'; elsif std_match(i_l,"11110---") then a_l<="100"; gs_l<='0';eo_l<='1'; elsif std_match(i_l,"111110--") then a_l<="101"; gs_l<='0';eo_l<='1'; elsif std_match(i_l,"1111110-") then a_l<="110"; gs_l<='0';eo_l<='1'; elsif std_match(i_l,"11111110") then a_l<="111"; gs_l<='0';eo_l<='1'; elsif std_match(i_l,"11111111") then a_l<="111"; gs_l<='1';eo_l<='0'; end if; else a_l<="111";gs_l<='1';eo_l<='1'; end if; end process; end Behavioral;
