10 years agoVHDL DE2 board - write bmp file to SDRAM display via vga
Hello all, I'm trying to save a bmp file to the sdram on altera DE2 board and display that file, via the vga dac, on screen. i have manged to find a vhdl code for the vga part, but having troubl...
10 years agoI'd start with a working example project for your board that uses the SD ram. Use a copy of that as your starting point. Make small changes to implement the other functions you need. Start with simple stuff. Walk before running etc.
