emaferna
5 years agoVHDL Configuration for TestBenches Issue
I have a very simple entity (an AND 2 input gate) named myAnd2 with an architecture (named ex1), as top level design unit.
I also have a testbench with two architecture (named test1, test...
emaferna
5 years agoSorry, I did a syntax error in the previus post: the architecture in the configuration is test1.
This error was made only in writing the post, not in the running vhdl code.
configuration Tester of TestBench is
for test1
for gateTst1 : device1
use entity WORK.myAnd2(ex1)
port map (x => a, y => b, z => c);
end for;
end for;
end configuration Tester;
