8 years agoVHDL code works when compiled on Quartus Prime V15.1 but breaks on V17.1
Hello, I have code working on a hardware design that was compiled using Quartus Prime version 15.1. I installed QP version 17.1 and compiled the same code but the code did not work as expected. I ...
8 years agoSorry I cannot help you, byt can you edit your post so the opening code tag is after your text and before the actual code? That 'll show the red text you mention as well as make the code more readible. Maybe you could also remove the many <br> tags?
