12 years agoVHDL code help!
Hi guys, I have written out this code, but it gave me error that type R1-R5 is incompatible with A-E. Please help !!!
12 years ago --- Quote Start --- Please post your modifed code. The fact the auto-generated testbench still uses std logic makes me beleive you modified nothing. And you shouldnt need to use the auto-generation - you can write it yourself. --- Quote End --- I modified them manually, and it does not give me errors after i synthesized, so i believe its working? Can teach me how to write test bench manually without auto generated code?
