8 years agoVHDL Code For Ultrasonic Distance Sensor HC-SR04
I am trying to write the VHDL code for it but it is not working, it shows always 00 ( cm1 = 0 and cm0 = 0). Can you pleaseee help me? Do you detect any problem in the code: Summation of how the...
8 years agoYes I realized that mistake. I edited my code accordingly this way, but it still does not work. It either shows 99 or 00 after each reprograming the FPGA. Also I don't know how to write the testbench:( I would appreciate if you write it for me( I believe it is quite easy for a given code, otherwise I wouldn't ask such a thing.). The new code is:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity sonar is
Port ( clk : in STD_LOGIC;
trig : out STD_LOGIC;--trigger
echo : in STD_LOGIC;
cm1 : out unsigned(3 downto 0); --most significant bit of distance in binary form
cm0 : out unsigned(3 downto 0));
end sonar;
architecture sonar_arch of sonar is
begin
process(clk)
variable count: integer range 0 to 10000;
variable tmpcm1: unsigned(3 downto 0) := "0000";
variable tmpcm0 : unsigned(3 downto 0) := "0000";
variable sendTrig: std_logic := '1';
variable echoPrev: std_logic:= '0';
variable echoCurrent : std_logic:= '0';
begin
if rising_edge(clk) then
if sendTrig = '1' then -- send 10us trig
if count = 1000 then -- 10 us trig is completed, reset tmp signals for the new calculation
trig <= '0';
sendTrig := '0';
count := 0;
tmpcm0 := "0000";
tmpcm1 := "0000";
else
trig <= '1';
count := count + 1;
end if;
else -- stop sending trig, do the calculation (5800 clk cycle = 1cm)(count enters here as 0)
if echo = '1' then -- we can start calculating the width of the echo
if count = 5799 then--we measuered 1 cm
if tmpcm0 = "1001" then
if tmpcm1 = "1001" then
sendTrig := '1';--max distance to be measured(100 cm), stop measuring, re-send the trig(also update the output)
cm0 <= tmpcm0;
cm1 <= tmpcm1;
else
tmpcm1 := tmpcm1 + "0001";
tmpcm0 := "0000";
end if;
else
tmpcm0 := tmpcm0 + "0001";
end if;
count := 0;
else
count := count + 1;
end if;
if echoPrev = '1' and echoCurrent = '0' then --falling edge of echo, edit the output, start sending new trigger
sendTrig := '1';
cm0 <= tmpcm0;
cm1 <= tmpcm1;
end if;
end if;
end if;
echoPrev := echoCurrent;
echoCurrent := echo;
end if;
end process;
end sonar_arch;
