8 years agoVHDL Code For Ultrasonic Distance Sensor HC-SR04
I am trying to write the VHDL code for it but it is not working, it shows always 00 ( cm1 = 0 and cm0 = 0). Can you pleaseee help me? Do you detect any problem in the code: Summation of how the...
8 years agoWell, for a start, you have the following structure:
if echo = '1' then
if echo = '0' then
--this is impossible, as echo cannot be '1' and '0' at the same time
This case will never occur. If you have a "working" simulation, but it's not working in hardware, then I suggest there is something wrong with how you're testing your code. Maybe you misunderstood how the echo works? or how some other interface should work?
