VHDL Aggregate Error
It's hard to tell with the formatting, but you have two if statements in the process with the same if check at the same level: If (enable='1'). Perhaps one or the other of these checks should be if (enable='0').
I put the process in code tags to make it slightly easier to read below.
Also, you put enable in the sensitivity list, which makes it function as an asynchronous reset instead of an enable signal, which is usually synchronous. I don't know if that's what you're intending.
As far as the aggregate error is concerned, the only aggregate I see is in your case statement which doesn't look like it should be an issue. Usually the error points to a line number, so I don't know if there's other code missing here or what.
#iwork4intel
process (clk, enable)--code for FF/MOD
begin
If (enable='1') then
time_count<=0;
cake<='0';
Elsif rising_edge (clk) then
If (time_count = 4999999) then
cake<= NOT cake;
time_count<=0;
Else
time_count<= time_count+1;--MOD count up
End If;
End If;
If (enable='1') then--when r is 0 the count will reset at 0
count <=0;
Elsif (rising_edge (cake)) then
If (count = 0) then--0
count<=9;--9
Else
count<=count+1;
End if;
If (count2 = 0) then--0
count2<=13;--13
Else
count2<=count2+1;
End If;
End if;
case (count, count2) is
when (count = 0 and count2 = 0) =>
LED(0)<='1';
when (count = 1 and count2 = 1) =>
LED(1)<='1';
when (count = 2 and count2 = 2) =>
LED(2)<='1';
when (count = 3 and count2 = 3) =>
LED(3)<='1';
when (count = 4 and count2 = 4) =>
LED(4)<='1';
when (count = 5 and count2 = 5) =>
LED(5)<='1';
when (count = 6 and count2 = 6) =>
LED(6)<='1';
when (count = 7 and count2 = 7) =>
LED(7)<='1';
when (count = 8 and count2 = 8) =>
LED(8)<='1';
end case;
End process;I am trying to make a mod 13 counter and mod 9 counter go against each other so when they both hit 2 at the same time, an LED will light up. I am programming whack a mole.
