11 years agoVHDL 8 bits comparator using 2 * 4 bits comaparator
Hay everyone ,
i am trying to simulate a 8 bits comparator using 2 * 4 bits comparators here's my code .... it's compile --> no errors but i have 3 red lignes in the wave this is the 4bits comparator (with 3 outputs ega , inf and sup)
Library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity Comp_4Bits is
port(
A : in std_logic_vector (3 downto 0);
B : in std_logic_vector (3 downto 0);
SUP : out std_logic;
iNF : out std_logic;
EGA : out std_logic);
end Comp_4Bits ;
Architecture RTL of Comp_4Bits is
begin
process(A, B )
begin
if (A> B then Sup <='1' ; Inf <='0' ; Ega <='0' ;
Elsif (A< Bthen Inf <='1' ; Sup <='0' ; ega <='0' ;
elsif (A= B then Ega <='1' ; sup <='0' ; inf <='0' ;
end if ;
end process ;
end RTL;
and here is the code of 8 bits comparator
library ieee;
use ieee.numeric_std ;
entity compa_8bits is port(
A:in std_logic_vector(7 downto 0);
B:in std_logic_vector(7 downto 0);
ega : out std_logic ;
sup : out std_logic;
inf : out std_logic
end compa_8bits;
architecture RTL of compa_8bits is
signal sup1 , sup2 , inf1 , inf2 , ega1 , ega2 , sig1 , sig2:std_logic;
component Comp_4Bits is port(
A:IN std_logic_vector(3 downto 0);
B:IN std_logic_vector(3 downto 0);
ega : out std_logic;
inf : out std_logic);
end component ;
begin
u1:Comp_4Bits port map
A =>A(7 downto 4),
B=>B(7 downto 4),
ega=>ega1 ,
sup=>sup1,
inf=>inf1
u2:Comp_4Bits port map
A=>A(3 downto 0),
B=>B(3 downto 0),
ega=>ega2,
sup=>sup2,
inf=>inf2);
inf <= inf1 or (ega1 and inf2);
sup <= sup1 or (ega1 and sup2);
ega <= ega1 and ega2;
END RTL;
and finally the test bench
library ieee;
entity compa_8bits_tb is
end compa_8bits_tb;
architecture BHV of compa_8bits_tb is
component compa_8bits is
port(
A:IN std_logic_vector(7 downto 0);
B:IN std_logic_vector(7 downto 0);
inf : out std_logic
end component;
signal A, B : std_logic_vector( 7 downto 0) ;
signal ega, inf, sup: std_logic;
begin
Dut1: compa_8bits port map(
A => A ,
B => B ,
ega=>ega ,
sup =>sup,
inf=>inf
process
begin
A<="11110000";
B<="01101111";
wait for 20 ns;
A<="01110000";
B<="01110000";
wait for 30 ns;
A<="10011111";
B<="01101010";
end process;
end BHV;
thanks a lot =D
