VHDL 2008 unary or operator
Hi Vicky,
Thanks for responding.
Here is an example that compiles in ModelSim, but not in Quartus.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity MyFlags is
port
clock: in std_logic;
my_flags: in boolean_vector(7 downto 0)
end;
architecture V1 of MyFlags is
constant MY_FLAGS_FALSE: boolean_vector(my_flags'range) := (others => false);
begin
process(clock)
begin
if rising_edge(clock) then
-- OK: Compiles in Quartus.
if not(my_flags = MY_FLAGS_FALSE) then
-- Do something.
end if;
if my_flags /= MY_FLAGS_FALSE then
-- Do something.
end if;
if my_flags = (my_flags'range => false) then
-- Do something.
end if;
-- Not OK: Won't compile in Quartus, but compiles successfully in ModelSim.
if or my_flags then
-- Do something.
end if;
if or(my_flags) then
-- Do something.
end if;
end if;
end process;
end;Error messages:
Error (10500): VHDL syntax error at test.vhd(38) near text "or"; expecting "(", or an identifier ("or" is a reserved keyword), or unary operator
Error (10500): VHDL syntax error at test.vhd(43) near text "or"; expecting "(", or an identifier ("or" is a reserved keyword), or unary operator
Error (10500): VHDL syntax error at test.vhd(43) near text "then"; expecting ":=", or "<="
It's not obvious to me what the problem is. Could you enlighten me?
Tim.
Thanks for the patience & details.
Are there any other options that I need to select in Quartus to enable proper compilation of IEEE Std 1076-2008?--- -- -- Intel Quartus Pro edition has full support for VHDL-2008, Intel Quartus Standard has limited support, please refer the Page-7 from link below & check your Quartus edition.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/br/br-quartus-prime-software.pdf
Vicky
