StefanB
6 years agovhdl 2008: read output / unary operator
Hi
Attached you will find a VHDL-file, which implements an FSM and uses the function "next_crc16_d8(..)" to calculate the CRC.
The file compiles fine for Questa, but fails in QuartusPrime 18.1 on...
JC_FPGA
6 years agoI've also encountered this lack of support for VHDL-2008. I often get my code simulating properly in Questa only to find that a VHDL code construct I used isn't supported by Quartus.
OSVVM and UVVM are getting more traction. Intel should really focus on supporting more the features of VHDL-2008.
Following this thread in case you get a solution...
