11 years agoVHDL : Problem with 4-Bit Adder and Subtractor !
Hi I want to make a 4-Bit Adder and Subtractor with VHDL I have created 1-Bit Full-Adder , XOR Gate ( for Subtract ) and a 4-Bit Adder as shown below : Full-Adder :
LIBRARY ieee; USE i...
11 years agoThe simple Chart is like this :
http://www.alteraforum.com/forum/attachment.php?attachmentid=10757&stc=1 I made some changes New ALU Code :
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
USE ieee.std_logic_unsigned.ALL;
ENTITY ALU IS
PORT(
--Clk : IN STD_LOGIC;
A : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
B : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
As : INOUT STD_LOGIC;
Bs : IN STD_LOGIC;
Mode : IN STD_LOGIC;
AVF : OUT STD_LOGIC
END ALU;
ARCHITECTURE Declare OF ALU IS
COMPONENT Adder_4_Bit IS
PORT(
A, B : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
Sum : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
COut : OUT STD_LOGIC
END COMPONENT;
SIGNAL E : STD_LOGIC;
SIGNAL Sum : STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
Add : Adder_4_Bit PORT MAP(A, B, Mode, Sum, E);
PROCESS(As, Bs, A, B, Mode)
BEGIN
CASE Mode IS
WHEN '0' =>
IF ((As XOR Bs) = '1') THEN
AVF <= '0';
IF (E = '1') THEN
IF (Sum = "0000") THEN
As <= '0';
END IF;
ELSE
Sum <= (NOT Sum) + "0001";
As <= NOT As;
END IF;
ELSE
AVF <= E;
END IF;
WHEN '1' =>
AVF <= E;
ELSE
AVF <= '0';
IF (E = '1') THEN
As <= '0';
END IF;
ELSE
As <= NOT As;
END IF;
END IF;
WHEN Others =>
END CASE;
END PROCESS;
END Declare;
New Test Bench Code :
LIBRARY ieee;
ENTITY ALU_Test_Bench IS
END ALU_Test_Bench;
ARCHITECTURE Declare OF ALU_Test_Bench IS
COMPONENT ALU IS
PORT(
A : INOUT STD_LOGIC_VECTOR(3 DOWNTO 0);
Bs : IN STD_LOGIC;
AVF : OUT STD_LOGIC
END COMPONENT;
SIGNAL Xs, Ys, M, Av : STD_LOGIC;
SIGNAL X, Y : STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
ALU_PM : ALU PORT MAP(X, Y, Xs, Ys, M, Av);
Mode_Process : PROCESS
BEGIN
M <= '1';
WAIT FOR 10 ns;
M <= '0';
WAIT FOR 10 ns;
END PROCESS;
Calc_Process : PROCESS
BEGIN
X <= "0010";
Y <= "1011";
Xs <= '0';
Ys <= '1';
WAIT FOR 20 ns;
X <= "0110";
Y <= "0011";
Xs <= '1';
Ys <= '1';
WAIT FOR 20 ns;
X <= "0010";
Y <= "1011";
Xs <= '0';
Ys <= '1';
WAIT FOR 20 ns;
END PROCESS;
END Declare;
but when I tried to simulate test bench, got the result below !! : http://www.alteraforum.com/forum/attachment.php?attachmentid=10758&stc=1 Why the X value is 'U' ?!? what goes wrong with my Test-Bench ? * Edit : I tested ALU , Problem is in ALU that Set Value of Sum to 'U' I can`t find the problem ! , help please ! ...
