11 years agoVHDL : Problem with 4-Bit Adder and Subtractor !
Hi I want to make a 4-Bit Adder and Subtractor with VHDL I have created 1-Bit Full-Adder , XOR Gate ( for Subtract ) and a 4-Bit Adder as shown below : Full-Adder :
LIBRARY ieee; USE i...
11 years agoI made some changes
I made a ALU unit as :
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
USE ieee.std_logic_unsigned.ALL;
ENTITY ALU IS
PORT(
--Clk : IN STD_LOGIC;
A, B : IN STD_LOGIC_VECTOR(4 DOWNTO 0);
Sel : IN STD_LOGIC;
AOut : OUT STD_LOGIC_VECTOR(4 DOWNTO 0);
AsO : OUT STD_LOGIC
END ALU;
ARCHITECTURE Declare OF ALU IS
COMPONENT Adder_4_Bit IS
PORT(
A, B : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
Mode : IN STD_LOGIC;
Sum : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
COut : OUT STD_LOGIC
END COMPONENT;
SIGNAL As, Bs, E, AVF : STD_LOGIC;
SIGNAL XA, XB, Sum : STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL Mode : STD_LOGIC;
BEGIN
Add : Adder_4_Bit
PORT MAP(XA, XB, Mode, Sum, E);
PROCESS
BEGIN
As <= A(4);
Bs <= B(4);
XA <= A(3 DOWNTO 0);
XB <= B(3 DOWNTO 0);
CASE Sel IS
WHEN '0' =>
IF ((As XOR Bs) = '1') THEN
Mode <= '1';
AVF <= '0';
WAIT ON Sum;
IF (E = '1') THEN
IF (Sum = "0000") THEN
As <= '0';
END IF;
ELSE
Sum <= (NOT Sum) + "0001";
As <= NOT As;
END IF;
ELSE
Mode <= '0';
WAIT ON Sum;
END IF;
AOut <= Sum;
AsO <= As;
WHEN '1' =>
Mode <= '0';
WAIT ON Sum;
AVF <= E;
ELSE
Mode <= '1';
WAIT ON Sum;
AVF <= '0';
IF (E = '1') THEN
As <= '0';
END IF;
ELSE
As <= NOT As;
END IF;
END IF;
AOut <= Sum;
AsO <= As;
WHEN Others =>
END CASE;
END PROCESS;
END Declare;
and A Test Bench like this :
LIBRARY ieee;
ENTITY ALU_Test_Bench IS
END ALU_Test_Bench;
ARCHITECTURE Declare OF ALU_Test_Bench IS
COMPONENT ALU IS
PORT(
Sel : IN STD_LOGIC;
AsO : OUT STD_LOGIC
END COMPONENT;
SIGNAL Xs, S : STD_LOGIC;
SIGNAL X, Y, O : STD_LOGIC_VECTOR(4 DOWNTO 0);
BEGIN
ALU_PM : ALU PORT MAP(X, Y, S, O, Xs);
Main_Process : PROCESS
BEGIN
WAIT FOR 100 ns;
X <= "00010";
Y <= "11011";
S <= '0';
WAIT FOR 30 ns;
S <= '1';
WAIT FOR 30 ns;
WAIT FOR 100 ns;
X <= "01110";
Y <= "10011";
S <= '0';
WAIT FOR 30 ns;
S <= '1';
WAIT FOR 30 ns;
WAIT FOR 100 ns;
X <= "10011";
Y <= "11111";
S <= '0';
WAIT FOR 30 ns;
S <= '1';
WAIT FOR 30 ns;
END PROCESS;
END Declare;
As i say , i want to model the algorithm i posted in first post there is some problem ... for example when i simulate and run test bench , there is no output value in O and Xs ! I know the problem is in ALU and Test Bench I changed ALU many times and tested many ways but all times some things goes wrong ! If you want to code that algorithm , which units you will create or at all what will you create ?! and how will you code that ?! thanks for your help ...
