10 years agoVHDL - (4-bit Adder) Combinational Logic: Hierarchical Design
Hi, I'm new to VHDL and have an issue with a required project and I was hoping someone could help with my code. I'm unable to get my program to compile and not exactly sure what I'm doing wrong. ...
10 years agoHi Tricky,
Appreciate the info, it was really informative. Also, I really like the style of the code you provided, definitely looks much cleaner, but I'm not sure if the code would work exactly with my project. I probably should've mentioned that the project is an assignment and most of the code that I posted was provided so I'm sorta stuck with it. The code I provided was the bottom part between the BEGIN & END imp. I tried using the code you provided just to see how it would work and I received the following error code. Sure it was something I probably did being a newbie. Error (10481): VHDL Use Clause error at Adder4.vhd(25): design library "work" does not contain primary unit "Adder1" Thanks
