10 years agoVHDL - (4-bit Adder) Combinational Logic: Hierarchical Design
Hi, I'm new to VHDL and have an issue with a required project and I was hoping someone could help with my code. I'm unable to get my program to compile and not exactly sure what I'm doing wrong. ...
10 years agoYou have connected a signal called cIn to the A1 instance of Adder1, but you have no local signal called cIn.
PS> There are 2 coding styles I would not recommend here: 1. Positional association. You can easily put signals in the wrong place. Much better to use named association: 2. I also dont like the use of components when the source is also VHDL. It means you have to maintain the same code in 2 places (and they must match). And you wont find problems until the elaboration phase (which for big designs can take a few minutes). Using direct instantiation means you can find the problem in seconds rather than minutes as the compiler checks the code directly against the entity.
A3: entity work.Adder1 --direct instantiation, no need for component.
port map (
a => a(2),
b => b(2),
cIn => carry_sig(1),
sum => sum(2),
cOut => carry_sig(2)
