11 years agoVGA monitor
Hi guys. I am trying to connect altera de2-115 board with VGA monitor. My coding was sucessful with no error. But, I have problem when downloaded the coding into fpga. Here is the problem (att...
11 years agoHi Daixiwen,
Thanks for your reply. Here is my vga_sync entity. Whenever I download the program into fpga, my VGA monitor is going to sleep mode. Why this happen? Thanks for your help. VGA SYNC: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity vga_sync is port (clk,reset: in std_logic; hsync,vsync: out std_logic; video_on, p_tick: out std_logic; pixel_x, pixel_y: out std_logic_vector (9 downto 0)); end vga_sync; architecture arch of vga_sync is --VGA 640-by-480 sync parameters constant HD: integer:=640; constant HF: integer:=16; constant HB: integer:=48; constant HR: integer:=96; constant VD: integer:=480; constant VF: integer:=10; constant VB: integer:=33; constant VR: integer:=2; --mod-2 counter signal mod2_reg,mod2_next:std_logic; --sync counter signal v_count_reg, v_count_next: unsigned (9 downto 0); signal h_count_reg, h_count_next: unsigned (9 downto 0); --output buffer signal v_sync_reg, h_sync_reg: std_logic; signal v_sync_next, h_sync_next:std_logic; --status signal signal h_end, v_end, pixel_tick: std_logic; begin --register process (clk,reset) begin if reset='1' then mod2_reg <= '0'; v_count_reg <= (others=> '0'); h_count_reg <= (others=> '0'); v_sync_reg <= '0'; h_sync_reg <= '0'; elsif (clk' event and clk='1') then mod2_reg <= mod2_next; v_count_reg <=v_count_next; h_count_reg <=h_count_next; v_sync_reg <=V_sync_next; h_sync_reg <=h_sync_next; end if; end process; --mod-2 circuit to generate 25MHz enable tick mod2_next <= not mod2_reg; --25MHz pixel tick pixel_tick <= '1' when mod2_reg='1' else '0'; --status h_end <= --end of horizontal center '1'when h_count_reg=(HD+HF+HB+HR-1) else --799 '0'; v_end <=--end of vertical '1'when h_count_reg=(VD+VF+VB+VR-1) else --799 '0'; --mod -800 horizontal sync counter process (h_count_reg,h_end,pixel_tick) begin if pixel_tick='1'then if h_end ='1' then h_count_next <= (others=>'0'); else h_count_next <= h_count_reg + 1; end if ; else h_count_next <= h_count_reg; end if ; end process; -- mod-525 vertical sync counter process (v_count_reg,v_end,pixel_tick) begin if pixel_tick='1'then if v_end = '1' then v_count_next <= (others=>'0'); else v_count_next <= v_count_reg + 1; end if; else v_count_next <= v_count_reg; end if; end process; -- horizontal and vertical sync, buffered to avoid glitch h_sync_next <= '1' when (h_count_reg>=(HD+HF)) --656 and (h_count_reg<=( HD+HF+HR-1 )) else --751 '0'; v_sync_next <= '1' when (v_count_reg>=(VD+VF))--490 and (v_count_reg<=( VD+VF+VR-1 )) else --491 '0'; --video on/off video_on <= '1' when (h_count_reg<HD) and (v_count_reg<VD) else '0'; --output signal hsync <=h_sync_reg; vsync <=v_sync_reg; pixel_x <=std_logic_vector (h_count_reg); pixel_y <=std_logic_vector (v_count_reg); p_tick <=pixel_tick; end arch; Here is my top level. VGA TEST library ieee; use ieee.std_logic_1164.all; entity vga_test is port( clk, reset: in std_logic; sw: in std_logic_vector(7 downto 0); hsync, vsync: out std_logic; red,green,blue: out std_logic_vector(7 downto 0)); end vga_test; architecture arch of vga_test is signal red_reg: std_logic_vector(7 downto 0); signal green_reg: std_logic_vector(7 downto 0); signal blue_reg: std_logic_vector(7 downto 0); signal video_on: std_logic; begin -- instantiate VGA sync circuit vga_sync_unit: entity work.vga_sync port map(clk=>clk, reset=>reset, hsync=>hsync, vsync=>vsync, video_on=>video_on, p_tick=>open, pixel_x=>open, pixel_y=>open); process(clk, reset) -- rgb buffer begin if (reset = '1') then red_reg <= (others => '0') ; green_reg <= (others => '0') ; blue_reg <= (others => '0') ; elsif (clk' event and clk = '1') then red_reg <= sw; green_reg <= sw; blue_reg <= sw; end if; end process; red <= red_reg when video_on = '1' else (others => '0'); green <= green_reg when video_on = '1' else (others => '0'); blue <= blue_reg when video_on = '1' else (others => '0'); end arch;
