11 years agoVGA monitor
Hi guys. I am trying to connect altera de2-115 board with VGA monitor. My coding was sucessful with no error. But, I have problem when downloaded the coding into fpga. Here is the problem (att...
11 years agoYou could check the sync signals with a scope too. 29Hz seems a bit low for the vertical sync rate. Doubling both frequencies would be a bit more in the correct range for a 640*480 VGA signal, so I wonder if your vga_sync entity isn't expecting a clock at a rate that is the double than the current value.
